Horton Stone Wall Set
I originally made this wall set some time ago for a church I was building and was happy with the way they turned out.  Then when I made Polgannon, I decided to use the set for most of the buildings in that neighbourhood in order to give it a cohesive appearance.
There are thirteen walls in the pack, mostly meant for exterior surfaces but there is also one which is half-plastered for interior walls (the top part being taken from EAxis's own paste plaster wall for easy matching).
Thanks to Granny by Gaslight for the stone texture.  The trims, coping, string course, quoining, dado etc. are taken and recoloured from other EAxis walls.
.zip   max_HortonWallSet.zip (Size: 548.08 KB / Downloads: 872)
