This is my entry for the SimPearls Wallpaper Makes the Room contest for February 2023
I have been meaning to post this set for nearly 18 months since I made it but I stopped making stuff for TS2 and didn't finish it. Well, now I have so here is the set. It includes the two walls I put in for the contest (above) plus three more pairs (patterned wall with toning plaster). They are all taken from patterns offered by John Lewis. For those of you who don't know, this is a large British retailer that specialises in homewares and is thought to be good quality and tasteful without being over posh. I like the shop anyway.
max_JohnLewisFlowerWallpapers.rar (Size: 331.64 KB / Downloads: 405)
The patterns can be found under wallpapers and cost $8, while the plasters can be found under paint and cost $7. They are Cow Parsley, Pomegranate (the one used in the contest), Pom Pom Pink and Harlequin. The textures are taken from the John Lewis site though all of them are rather older now.
Swatch:
As is usual with walls I make for TS2, the top of the wall and fittings (crown) are made to work with the ceilings in game and therefore will have a blank strip at the top of the texture. You can see this if you play with ceilings turned off or if the ceiling is not visible.
Swatch for contest
Swatch:
Swatch for contest
