Goldenrosen Landhaus - an Alpine hotel
This lot was originally posted at MTS after it was made for the Wanderlust contest held in 2018.  This was my third submission to that contest. This is what I said about it at the time:
"A Ski Chalet in Waldigrenze Valley...
So, the first time I ever went skiing about a million years ago in Italy as a teenager, I didn't know it then, but I stayed in a classic Alpen chalet. I discovered a number of other things on that trip including cappucinos, that U-shaped and hanging valleys were, in fact, a thing despite what I thought about them in Geography classes and that proper Italian pasta, cooked by Italians tastes divine just dressed with olive oil and salt and pepper. So, in memory of that trip and in tribute to all things European (because I'm apparently not going to be one much longer), I present das Goldenrosen Landhaus, my version of an Alpine ski chalet (this one based in Austria by the name). These buildings are usually made of stone and wood and have interiors which feature warm wood tones, fur rugs and roaring fires - which is what I was going for."
.zip   max_GoldenrosenLandhaus.zip (Size: 1.76 MB / Downloads: 7) (more pictures below - scroll right down to bottom.  CC is in rar here on Sims File Share - explanation below of all included (or not))
This is a hotel lot. There are six rentable colour-coded bedrooms with attached bathrooms, a lounge with a bar, a dining room and a sauna. The rooms are a mix of single, double and family. It makes an ideal base for a mountain getaway (with skiing - how I wish sims could ski (I know about Chris Hatch's mod - just wish EAxis had done it, a winter sports EP would've been great)). The lot was made in AGS in an empty neighbourhood, has been cleaned of any sim references and then treated with Chris Hatch's lot cleaner. The Sims2Pack file was saved without any CC - you will have to download the needed CC (see below). You can load the lot without the CC but you will get a very stripped down version (decorate it yourself!) and a very pretty birch tree garden - not what was intended but nice anyway. Despite what the pictures show, the lot has never been played - those pictures are from a test version (so it has been play-tested).
Note
I used the Mountain Fireplace in this lot. This is a BV fireplace which comes without a base (why EAxis?). To get round this problem, I built a piece of foundation underneath the bottom of the fireplace outside the lot (using the Lot Adjuster to do so). However, you might want to investigate this fix by Huge Lunatic at MTS and delete-and-replace the fireplace (deleting the foundation tile first) to get a base to generate. I didn't include this in the CC because it's a default/recolourable replacement mod.
BTW, the phone was moved but might reset when you place the lot.  This is where it's meant to be.
Custom Content
There is quite a bit of CC used in the lot and a complete list follows. I packed the lot up without its CC but there is a link at the bottom of the page with a bundled rar file with all CC included to save you chasing round for it. All CC is included in the bundle except two items - Reyn's Open Underneath Deck Stairs and an OMSP (see below for links). If you don't have those items already, I'd advise you to go and get them since they are both a great enhancement to the game.
Content made by me
I made some CC for the lot as follows.  These are included in the bundle but are also available here on this site (with some extras not used on this particular lot)
  • Chalet walls and floors - there are two wooden interior chalet walls made using a texture from High Resolution Textures. These are found in Paneling and cost $8.
  • and a lovely wooden chalet floor with a texture from The Foundary, found in wooden floors and costing $7.
  • There are three lodge walls - a wide-logged one called Log Cabin Siding used on the upper floors on the outside of the chalet and two narrower-logged walls, called Clapboard Siding, used on the sauna and the roof level, one horizontally laid, the other vertical. These textures were made by me (quite a long time ago now too). These are in Siding and cost $8.
  • There is a simple brown recolour of the in-game Goth Aged Wood floor (see comparison picture) which was used for the ceilings. This is also in wooden floors and costs $8 (that was a mistake - it should be $6).
  • Recolours of EAxis's Modern Tile GO! walls used in the bathrooms in yellow, purple and brown (there is also an orange version in the walls section of this site - it's not used here but I wanted that colour for the set). These were made so I could colour match the bedrooms and bathrooms. They are in Tiles and cost $1 just like the originals.
  • Recolours of the IKEA SVEJE Rug used in the bathrooms in purple and brown (again an extra orange recolour elsewhere on this site and done for the same reason). I've always liked using these rugs in bathrooms. The rug is in Decorative>Rugs and costs $19.
Custom Content from elsewhere
Not included and not in bundle
Reyn's open underneath wooden deck stairs here and you also need Numenor's recolourable stairs too so that these work. The stairs used though aren't recoloured - they're just the base colour.
One of Silent Lucidity's OMSPs (small one, no. 3) from here.
Neither of these things is absolutely essential. If you don't have them already, both are really useful additions to the game but if you don't install, the game will just default to the regular deck stairs and give you a couple of free-floating wall shelves. You will need to replace the stairs in that case. I didn't include them in the bundle since they are such common CC and many, many people already have them.
Not included in lot file but bundled - you can use the links to find all the files or use my all-in-one bundle file, linked below.
4ESF Bushes here
4ESF Outdoor6 Olive bush
4ESF Outdoor6 Shrub and dark recolour
Faux Parisian Wall Clock by Adele
http://modthesims.info/d/282038
Aspire set by ulmille here
Aspire Ceiling Lamp med
Aspire Placemats made by ulmille plus recolour 2
Aspire Vase
Aspire Fireplace Wood
Around the Sims
ATS Magazines plus englishdeco recolour from the Beauty Salon set: here
From the Irish Pub Set: here
ATS Irish Pub - Bottle of beer 001
ATS Irish Pub - Decorative bottles 001 plus 'more' recolour
ATS Irish Pub - Decorative bottles 002
ATS Irish Pub - Glass of beer 001 plus 'more' recolour
ATS irish Pub - Hanging bottles 001 plus 'more' recolour
Skis From the Sports set: here
Skis plus yellow recolour
Beddings - taken from several places as follows. Some are rather old and, in a couple of cases, I have edited the textures to remove fuzzy areas and other small blemishes.
MJS Bedding by JupiterStar - Sugar and Spice 2_01
http://modthesims.info/d/483667
pjbedding Quilt 03 - I cannot find this one anywhere. I thought it was a fairly recently released file. If anyone knows who made it, please let me know. It's the yellow squared quilted bedspread
Red Sonja's Country Star 3 Quilt
http://www.modthesims.info/download.php?t=588783
S2D Red Crazy Quilt (edited) - by Sims 2 Day. It's a very old file (where I have tidied up the texture a little). Wayback Machine shows the site but no pictures - seems to be on p.35 of the bedding archive. Sims2Day is on the Graveyard as far as I know but the Graveyard is currently down so I can't check.
Simcastic Green Velvet Bedspread (edited)
Site long gone: The bedspread was one of four which can be seen on page four on the site's image on the Wayback Machine the files are also available at the Graveyard though that is currently down.
sunni Merlotte Bedding
http://www.sunni.us/merlottes.htm
Contempo Good Livin' chair by Bedwyr
Recolours in chestnut, custard, damson, herbgarden, maple and ocean here
Belle Maison Basic and Flower Circle Carpets by SweetAmberkins in Espresso, Forest, Midnight, Rouge, Royale, Tuscan
http://modthesims.info/d/583633
Pine trees and Snowdrops by Bienchen at http://sim2me.de. You can't give the direct download page link to this site but all are under Downloads>Objects>Plants and then 'Seasons Plants'
Pinie, gross
Pinie, klein plus blau, dunkler and gruener recolours
Pinie, lang plus dunkler and gruener recolours
Schneegloeckchen
BV and AL Recolours by Michelle
BV Bar seat Cushion Green Leather
http://modthesims.info/download.php?t=584192
BV Double Bed in Blackwood, Mahogany, White
BV Dresser (Foreign Flavour Dresser) in Blackwood, Mahogany, Whitewood
BV End Table (End Table by Splendid Scenes) in Blackwood, Mahogany, Whitewood
BV Single Bed in Blackwood, Mahogany, Whitewood
http://modthesims.info/download.php?t=581307
BV Customer's First Dining Table in Blackwood, Mahogany, Whitewood
BV TV Unit (Stationary Concierge by Splendid Scene) in Blackwood, Mahogany, Whitewood
http://modthesims.info/download.php?t=583215
Mission Coffee Table in AL Medwood
http://modthesims.info/download.php?t=587485
Easy Swing Door AL Med Wood
Solidity Door AL Medwood
http://modthesims.info/download.php?t=470796
Value Wood Lumbers Justa Door in AL Medwood
http://modthesims.info/download.php?t=518357
Macarossi Fancifully Fuzzy Fern
http://modthesims.info/d/190397
Original EA Sims Content
Decorative Plate "Mountain World" This object has been exclusively created for "Das offizielle die Sims 2 Magazin". www.Sims2Magazin.de - this was a downloadable freebie with BV
Gwenke plants at sims2artists.com
Rowan tree
https://sims2artists.com/index.php?topic=3294.0
Live large shrubby shrub (midbiscus) plus dark and olive recolours
https://sims2artists.com/index.php?topic=3402.0
Wild anemones
https://sims2artists.com/index.php?topic=3361.0
Dining Set by Hek
http://modthesims.info/d/280691
Polsterstuhl plus dunkel braun streifen (cushions) and buche dunkel (wooden frame) recolours
Massiver Holztisch (one tile) plus buche dunkel recolour
Massiver Holztisch (two tile)
Wooden Columns and Beams Redux by HugeLunatic
http://www.modthesims.info/download.php?t=427686
Horizontal Half Round Column 4 Tile
Horizontal Half Round Column 3 Tile
Vertical Round Column
kativip
Mushrooms AA
https://kativip.ucoz.ru/load/kativip/set...d/5-1-0-18
Grass SH: Homecoming Cemetery
https://kativip.ucoz.ru/load/kativip/set...y/5-1-0-32
Birch Tree Shrubby Larger by Khakidoo
http://modthesims.info/download.php?t=221689
Clump of grass mesh by Lethe_s
http://modthesims.info/d/202811
My Colonial Bathtub Curtain striped recolours in blue, candy apple red, green, lemon and lilac
https://littlecarping.com/mybb/showthread.php?tid=42
Miasmata conversions by Ohbehave (ohbehave007.blogspot.com). Download here
Items used:
Miasmata - Cabbage
Miasmata - Fern1 (MASTER)
Miasmata - Fern2 (SLAVE)
Miasmata - Fern3 (MASTER)
Miasmata - Fern5 (SLAVE)
Miasmata - Ground Clovers
Miasmata - Mushroom1
Miasmata - PineNeedles
Miasmata - Twigs1 (MASTER)
Miasmata - Twigs4 (MASTER)
Miasmata - Twigs5 (SLAVE)
Numenor - Lost and Found EAxis trees made usable
Scotch Pine http://modthesims.info/d/152290
Poppet Veil of Dream recolours in Red, Yellow, Brown, Darker Green, Darker Blue, Darker Purple
http://poppet-sims.tumblr.com/post/44023630505
Sleds by rosiedogsim http://modthesims.info/download.php?t=48331
A Sled to Hang on the Wall
Old Fashioned Wooden Sled
Link to bundle
I have packed all the CC up into a rar-file bundle which you can download in one for convenience. You can find it here on Sims File Share.  This is not all the CC bundled together in one package file (sometimes understood as the meaning of 'bundled') but simply a rar file containing all the CC files used separately (so you can delete those you don't want).
Thanks should go to Gayars for creating and hosting the contest, plus the judges and other contestants - that was a lot of fun! Also to Numenor for AGS and Chris Hatch for the lot cleaner tool.
Lot Size: 3x3
Lot Price (furnished): 166,832
